11 years agoMAX 10 dual configuration - Remote configuration mode
I currently have a Quartus II (v15.0.0) project where I would like to take advantage of dual compressed images for the MAX 10. However, when attempting to produce programming files for dual configuration, the following error arises - Error 169130: Configuration mode specified as Remote but remote update block is not found in design After reading the relevant documentation, it appears that the configuration mode defaults to Remote when dual configuration mode is selected. Is it possible to alter the configuration mode so that remote system update block is not required? Thanks2 Replies
You need to include the Dual Configuration IP core in the MAX 10 design since you want to use dual compressed images.
--- Quote Start --- You need to include the Dual Configuration IP core in the MAX 10 design since you want to use dual compressed images. --- Quote End --- How to include Dual Configuration IP in a project?
