MAX 10 Development Kit EtherCAT and ADC
Hi
Thanks for update. Based on my understanding, you need to buy the IP core. Kindly contact your nearest Intel salesperson or distributor.
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
And yes. The Ethernet ports be used for EtherCAT communication.
MAX 10 FPGA is not available in Quartus Pro. Refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf For software, it is advice to use Quartus version 15 and above.
Regarding “can code be reused” Could you elaborate more what do you means?
Hi
Thanks again for your reply! Regarding the IP core you mention to buy is the one for ADC or the one from Beckhoff to use EtherCAT over an FPGA?
Regarding reusing the code, I was meaning using the code developed with the MAX 10 development board discussed in this thread in a self-designed board including a MAX 10 FPGA.
Thank you!
