Matching timing constraints regularly fails when Full Moon
Yes, I regularly clean project files and I even remove rubbish left somewhere after removal. Normally I run Quartus with seed set e.g. to 1, then use Design Space Explorer to try 40 or 60 seeds. Meeting timing constraints never works when full moon time. Our design takes about 75% of logic resources, I use Windows 7. We have 2 iterations of the design, one in Cyclone III using Quartus 12.1, the other in Cyclone V using Quartus 17.1 or 18.1. Our design takes time stamp from a server, so a design varies every day as far as date (in separate vhdl file) concerns.
May be that time stamp causes that chaos ?
Hi IPaul, both version of quartus fail or just 17.1 18.1?
I am looking around on how to isolate my ghosts and skeleton...
If applicable, how long is in term of code line the file causing failure?
Yesterday bug appeared again on a large file then dissolved asap I trimmed commented code, I am investigating other troubled design...
I am thinking really odd influence from Van Hallen Belt and sun wind too ;)
