Master data width is more than slave data width in Qsys AXI bridge
I don't think the HPS bridges are the question here.
Can you specify which document you are referring to here? Different data widths between master and slave should be handled automatically when the interconnect is generated. I don't recall that this is an issue for Avalon or AXI. I don't know if you are using the Standard or Pro edition of the software, but here is the latest Platform Designer user guide for the Standard edition:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-platform-designer.pdf
#iwork4intel
Hi, thank you for your answer!
I have found this document - https://www.coursehero.com/file/31922700/qsys-interconnectpdf/ (see pp.61).
Yes, data width will be adjusted automatically when master data width < slave data width. I have found in this document that opposite situation (master data width > slave data width in AXI Bridge) is not supported by Qsys (is it right or I am mistaken?)
Actually, I tried to generate Qsys with master data width > slave data width, and it doesn't work right.
