17 years ago --- Quote Start --- Thanks pletz, it appears that SynplifyPremier can synthesize the DW_* components that I need directly without having to go through GTECH. --- Quote End --- Hi, maybe I found a workaround for your problem, which runs without SynplifyPremier. 1. Generate a netlist of your designware elements with your ASIC synthesis tool. 2. Limit the number of Library cells to a minimum. Write a e.g. verilog description for all used element. In case of arithmetic functions (e.g. adder) write a functional description, in order to make sure that the arithmetic resources of the FPGA could be used. This will reduce the Fmax decreasing by using a netlist to a minimum. 3. Add netlist and your "simple" Library to your Quartus project.
