17 years ago --- Quote Start --- GPK, Thank-you very much for taking the time to confirm that library mapping with my EDIF files can be done. I opened the project you sent me and indeed library mapping worked. In an attempt to figure out what I was missing, I modified my existing project to match your settings. I put the design file and lmf in an identical hiearchy ... same problem as before, didn't work. Then I made a brand new project, same files, same hiearchy, same project settings, and direct to lmf file. I worked properly, just as your project did. This is a little concerning to me because it means there is some aspect of the project settings I don't know how to control. Any Ideas? Is there some cache that needs clearing? Thanks, Eric --- Quote End --- Hi Eric, sometimes Quartus has problems with his own database located the "db" folder. In case of some strange behaviour I delete this db folder and run the project again. Often this helps. Kind regards GPK
