17 years ago --- Quote Start --- I still get the message once any time I edit either the design file or the .lmf file. Any attempts to compile following the first warning do not generate another warning. I have tried locating the custom .lmf in the lmf directory created when Quartus II was installed ... didn't help. Could this mean that for whatever reason, the .lmf is never being found? Can anyone see something wrong with the EDIF file that could cause this behavior? People are sucessfully using Library Mapping every day are they not? --- Quote End --- Hi deepblue, good news, I could run your testcase sucessfully. I have the project attached. Look under settings -> EDA tool settings how I define the path to your lmf. Have fun GPK
