17 years agoYes I am adding as a custom file with the method you described.
Tool name: Custom Format: EDIF Signal Names VCC: VCC GND: GND Library Mapping File File name: ../../altera/81/quartus/lmf/sta-alt1.lmf I have also tried modifiying syntax in the .lmf to match what is prescribed in the help files and also matching that of existing .lmf files included in the Quartus installed lmf library I have verified that if I manually replace NA2 with nand2 and I with inv, that the EDIF file will compile synthesize, fit and program correclty. It's just a matter of getting this mapping to work
