AAnch
8 years agomalloc selects Flash address for DMA transfers in memtest.c instead of SRAM
Hi, In the current design there is NIOSII, DMA, Flash & SRAM implemented targeted for Max 10 FPGA. Trying to perform the DMA transfer as per the reference memtest.c I see the below code in questi...
Ahmed_H_Intel1
7 years agoHi,
Are you trying to use the SGDMA to transfer data to or from SDRAM ? here I've created the system with SGDMA with no errors. Can you explain more about what you are facing of errors with screen-shoots of your design?
