18 years ago --- Quote Start --- its realy strange that i get errors of VERILOG - and I'm programming in VHDL.. --- Quote End --- That problem was fixed sometime between versions 4.2 and 7.2 (another reason to use the latest version). The 7.2 messages: --- Quote Start --- Info: ******************************************************************* Info: Running Quartus II Analysis & Synthesis Info: Version 7.2 Build 151 09/26/2007 SJ Full Version Info: Processing started: Tue Oct 30 15:56:51 2007 Info: Command: quartus_map --lower_priority --read_settings_files=on --write_settings_files=off verilog_warning_for_vhdl_design -c verilog_warning_for_vhdl_design Info: Found 2 design units, including 1 entities, in source file adder.vhd Info: Found design unit 1: adder-arc Info: Found entity 1: adder Error (10500): VHDL syntax error at fir.vhd(14) near text "architecture"; expecting ";" Error (10500): VHDL syntax error at fir.vhd(16) near text "component"; expecting "end", or "begin", or a declaration statement Error (10500): VHDL syntax error at fir.vhd(27) near text ":="; expecting ")", or "," Error (10396): VHDL syntax error at fir.vhd(33): name used in construct must match previously specified name "fir" Error (10523): Ignored construct fir at fir.vhd(4) due to previous errors Info: Found 0 design units, including 0 entities, in source file fir.vhd Error: Quartus II Analysis & Synthesis was unsuccessful. 5 errors, 0 warnings Info: Allocated 155 megabytes of memory during processing Error: Processing ended: Tue Oct 30 15:56:53 2007 Error: Elapsed time: 00:00:02 --- Quote End ---
