Making custom component visible to Platform Designer (Qsys)
Hello @sstrell ,
Thank you very much for your response and sorry for delay.
You are right that initially we use Platform Designer Component Editor to create _hw.tcl file and then are moving it to other location. But we are moving RTL files along with _hw.tcl file. And hence, RELATIVE path remains same.
In our case, we are used to place RTL files in hdl folder and _hw.tcl file remains in same folder in which hdl folder resides. Then, we are using following commands to add files.
add_fileset_file ./sls_i2c_mstr/i2cc_wrapper.sv SYSTEM_VERILOG PATH ./hdl/i2cc_wrapper.sv TOP_LEVEL_FILE add_fileset_file ./sls_i2c_mstr/i2cc_user_define.pkg.sv SYSTEM_VERILOG PATH ./hdl/i2cc_user_define.pkg.sv add_fileset_file ./sls_i2c_mstr/i2cc_dp_ram_mf.v VERILOG PATH ./hdl/i2cc_dp_ram_mf.v
Do you see any issue in this?
Thank you and Have a Nice Day!
Bhaumik
Try an absolute path instead of a relative path. I think the issue may be that the relative path is relative to the .qsys file, not relative to the _hw.tcl file.
- BDarji5 years ago
Hello @sstrell ,
Thank you for your response and continuous support.
I do not think that relative path is an issue here because of following reasons:
(1) Please refer following image. It states we can either use absolute or relative path.
(2) Note that if we use 'user_component.ipx' file method I described in initial post, there is no issue. RTL files are generated properly when Qsys system is generated. Hence, I think file path is fine.
What do you think?
Have a Nice Day!
Kind Regards,
Bhaumik
- sstrell5 years ago
Have you tried the absolute path? This may be a bug that does not follow the documentation. I've seen it happen.
Your .ipx solution is fine, but it's extra work you shouldn't have to do to make the IP visible.
- BDarji5 years ago
Hello @sstrell ,
Sorry for delayed response. And thank you for your response.
I have tried absolute path. Please have a look at following:
add_fileset_file ./sls_i2c_mstr/i2cc_wrapper.sv SYSTEM_VERILOG PATH "E:/designs/sls/i_i2cc/trunk/master/software/setup/resources/i2c_mstr/hardware/component/hdl/i2cc_wrapper.sv" TOP_LEVEL_FILE add_fileset_file ./sls_i2c_mstr/i2cc_user_define.pkg.sv SYSTEM_VERILOG PATH "E:/designs/sls/i_i2cc/trunk/master/software/setup/resources/i2c_mstr/hardware/component/hdl/i2cc_user_define.pkg.sv" add_fileset_file ./sls_i2c_mstr/i2cc_dp_ram_mf.v VERILOG PATH "E:/designs/sls/i_i2cc/trunk/master/software/setup/resources/i2c_mstr/hardware/component/hdl/i2cc_dp_ram_mf.v"But unfortunately it didn't help.
I have attached herewith one text file which shows messages which are generated by Qsys when we refresh system. See whether this gives any clue or not.
Thank you,
Bhaumik
