thank you very much everybody for the replies. I was able to align the stream sending first a header but sometimes the data got misaligned, I mean the alignment is not stable. Now I am trying to reduce the deserialization factor to 8 and use two clocks to send the whole data stream. Compiling and simulating again the code I have found something weird. I am able to align or not depending on the pattern I use to analyze. I mean, with certain patterns I am able to align but not with other ones.
My clock frequency is 20 MHz.
One more question, could I send somebody my code so you can have a look at it?
Thank you very much
