15 years agoDid you take into account the clock propagation skew? between endpoints.
IE the Setup and Hold minimums slacks are probably on different pins, and part of this reason would be clock propagation skew. I don't know how to break out he switch time out of timing quest, but if you had different output loadings on the pins, that would definitely cause differences as well.
