--- Quote Start ---
Does ALT_INBUF_DIF have a VHDL implementation available for use as a component?
--- Quote End ---
Your question is answered on the same Help page I copied from before. More from that Help page:
--- Quote Start ---
VHDL Component Declaration:
The following VHDL component declaration is located in the VHDL Design File (.vhd) ALTERA_PRIMITIVES_COMPONENTS.VHD located in the <Quartus II installation directory>\libraries\vhdl\altera directory.
component alt_inbuf_diff
generic(
io_standard : string := "NONE";
enable_bus_hold : string := "NONE";
weak_pull_up_resistor : string := "NONE";
termination : string := "NONE";
port(
i : in std_logic;
ibar : in std_logic;
o : out std_logic);
end component;
VHDL LIBRARY-USE Declaration:
The VHDL LIBRARY-USE declaration is not required if you use the VHDL Component Declaration.
LIBRARY altera;
USE altera.altera_primitives_components.all;
--- Quote End ---
