Husam_Iq's avatar
Husam_Iq
5 years ago
LUT Mask
Hello guys,
How can instantiate and initialize the look-up table in the Altera boards family?
the following code is working in Xilinx however it does not work when I run it on Quartus! I don't know what should I change to make it work. I am very new to Quartus software.
I get the following error message: Error (10482): VHDL error at LUT_1.vhd(29): object "LUT6_2" is used but not declared
library ieee;
use ieee.std_logic_1164.all;
entity luts_vhd is
port (
clk : in std_logic;
lut_in : in std_logic_vector(3 downto 0);
lut_out : out std_logic
end entity luts_vhd;
architecture rtl of luts_vhd is
signal lut_in_r : std_logic_vector(3 downto 0);
signal lut_out6_d : std_logic;
begin
lut_in_r <= lut_in;
lut_out <= lut_out6_d;
LUT_U0: LUT6_2
generic map (
INIT => X"0000000000000001"
port map (
A => lut_in_r(0),
B => lut_in_r(1),
C => lut_in_r(2),
D => lut_in_r(3),
O => lut_out6_d
end rtl;
  • sstrell's avatar
    sstrell
    You've instantiated LUT6_2 but you have no required component declaration for it, like this:
         component LUT6_2
               generic (INIT: std_logic_vector(15 downto 0);
               port(
                    A,B,C,D: in std_logic;
                    O: out std_logic);
          end component;
    • Husam_Iq's avatar
      Husam_Iq
      Thank you for your reply, actually I tried your suggestion but it still not working!
      • sstrell's avatar
        sstrell
        Same error message? Show your full code now.
  • Nurina's avatar
    Nurina
    Did the above reply help solve your problem?
