8 years agoLPM_CONSTANT from "default quartus libraries" or from "IP Catalog": differences
In Quartus 17.1, when I am editing a "Block Diagram/Schematic File", I can insert into the schematic an LPM_CONSTANT by means of the symbol tool (from the library "c:/quartus/17.1/quartus/libraries/"...
8 years agoHi,
--- Quote Start --- Are these differences intentional for Quartus 17.1? Or is there anything wrong in my software installation or configuration? --- Quote End --- Yes, you will find this difference in all versions of Quartus because one is symbol & other is IP. --- Quote Start --- (since I am used to that editor from my experience with older versions of Quartus; some components I need are not available in the "IP catalog", e.g. LPM_FF). Can I achieve this with Quartus 17.1, too? --- Quote End --- In older version “MegaWizard Plug-In Manager” option was available in the “Symbol” window but working principle of all versions are same In fact In older version also for “LPM_FF” MegaWizard Plug-In Manager is Inactive, also check by inserting symbol with & without “MegaWizard Plug-In Manager” option in symbol window. Check screenshots Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)
