16 years ago --- Quote Start --- Thanks to pletz and Rysc for your suggestions. For the most part the design is schematic and vhdl with a little verilog. Unfortunately VQM is not supported for Stratix III. We do not plan to do any cleanup of the current project. What I would like to know is how folks manage large team based designs so as avoid conflicts between internals of the various blocks. Is there a better way than bottom up design? Thanks! --- Quote End --- Hi, VQM-files are not longer supported for StratixIII. I got this answer also from Altera. They recommend to use design partitions. I think the only way for you is a bottom up design. What kind of problem do you have with that solution ? Kind regards GPK
