11 years ago --- Quote Start --- When is this update available? I'm having similar issues as aws4y (I think). All of the board diagnostics are working fine; I'm running Windows Visual Studio 2013 Professional, my environment is setup using > vcvars64.bat but at the moment all of my kernels are hanging, .... --- Quote End --- Ok here is an update: I tracked this down to a license file issue. I simply created another license file, downloaded the file, and then updated my License File Environment Variable; now the compilation seems to be working correctly. The Hello World example just completed and executed correctly. However, the -march=emulation option still does not work correctly, I'll post a separate report on that.
