9 years agoLogic utilization of hello-world vector add
Hello. I recently compiled the vector add hello world example which comes with the Terasic DE1 BSP (Cyclone V). The report file, which was generated during the compilation of the kernel says that alr...
9 years agoThanks for pointing out what to read.
So if I use the vector_Add example with eg. 1024 elements and put follwing attributes to the kernel: __attribute__((num_simd_work_items(4))) __attribute__((reqd_work_group_size(256,1,1)))__kernel void vector_add ...
there would run 4 kernels in parallel with 256 Work-Items processed in each of them? Need the simd factor * work_group_size = elements? On the intel-video guide: Writing OpenCL Programms for Intel FPGAs the executionmodel is devided into single work-item excecution (with loop-pipelining) and ndrange kernels: So if i want to use the dataparallel NDRange excecution i have to work with clenqueuendrangekernel + simd?
How can i "tell" the kernel that i want to use it as a Single Work-Item Excecution? (Video sayswith NDRange of (1,1,1), but i didn´t managed to get it work that way ) Whats the difference between the single Work-Item excecution which is set with the NDRange of (1,1,1) and the excecution from the vector_add example. Sorry for asking again, i tried to figure it out the entire day but couldn´t quite suceed ./ Thanks :)
