11 years agoLogic analyzer interface: Is there a way to set up Table size permanently?
Hi there.
this is something not critical, but really annoying. In Logic Analyzer Interface (LAI) the monitored signals are listed for each bank in a table. The table has four columns: Pin Index, Type, Alias and Name. I just want to make clear, which table I mean. This table seems to have a standard format (size) to which it falls back everytime you do something in LAI. This is really really really annoying me!!!! In times of wide-screens I just want to set the width of this table to something that fits to the window. But when I finally managed to make the table wider (which is also very tricky because it does not work on every try), I change the bank an Tadaaaa, the Table is reset to its itsy-bitsy-tiny size and I have to start fumble around to see my signals again. Yes, I know, I just could give them shorter names in the Alias-Fields. But this Field is also very tiny and besides, everytime I write something into it, THE TABLE IS RESETED TO ITS OLD SIZE!!!! GRRRRRRR!!! And so I have to expand it, to see, which Signal is next, give it an alias -> Size resetted and so on. So my question is: Is there a setting somewhere, where I can set a reset-value for the table size. Or how else can I make the size of the Table permanently wider?No RepliesBe the first to reply
