10 years agologging error in vhdl
I got this error several times: my code gets successfully compiled but the error is "Logging is not supported for this item" why this error is displayed, can anyone tell !!!!!!
10 years ago --- Quote Start --- error is:- Logging is not supported for this item: /camera/image what could be the possible cause ?? --- Quote End --- Files cannot be logged. Presumably you receive this error in response to a command that you issued to 'log image'; This command could come from either typing it in at the command line or as part of a TCL script. But wherever it is that you have 'log image', you must remove the command. This will not affect the functionality of your testbench. Kevin Jennings
