10 years agologging error in vhdl
I got this error several times: my code gets successfully compiled but the error is "Logging is not supported for this item" why this error is displayed, can anyone tell !!!!!!
10 years ago --- Quote Start --- What is this item? is it memory, a variable, a signal, etc.? If you could give some more information on this message such as when it occurs and in which program it will make helping you a lot easier. --- Quote End --- error is:- Logging is not supported for this item: /camera/image and in my test bench:- GENERIC( fi_n: STRING :="hexi.dat" ; -- Input hex file name tclk: TIME:= 100ns -- Clock speed ); FILE image: TEXT OPEN read_mode IS fi_n; what could be the possible cause ??
