11 years agoLocation constraints and timing analysis
Hi everyone, I'm working on an RGMII interface implemented in a Cyclone IV E FPGA. The data input stage consists in an ALT_DDIO to recover DDR data in high-speed link, but also directly co...
11 years agoHi Rysc,
Thanks for you very detailed answer and your tips :-) I'll take a look at routing and delay chains. From compile to compile it pass/fails. Moreover I need to know with a high level of accuracy the time of incoming packet so it is required to keep the same routing for each FPGA programming file version. Again, many thanks! JG
