Diego2
5 years agoload_rtl_netlist can't read compiler database
Hello
I'm new to Quartus and I'm trying to read back an elaborated design from quartus_syn, however when I run the 'load_rtl_netlist' I get the following error:
ERROR: Can't read compiler databas...
- 5 years ago
You may check the available command for each Quartus executables here: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/tclscriptrefmnl.pdf
KhaiY
KhaiChein_Y_Intel
5 years agoHi,
I have reported this to our developer. You may use GUI: Tools > Netlist Viewers > RTL Viewer as a workaround at the moment.
KhaiY
Diego2
5 years agoThanks
I'd like to run this command so that I can port my automation scripts from the xilinx environment. Is there any other command I could use to perform RTL search operations? Things like [get_ports ...], [get_clocks ...] etc?
Diego
