Diego2
5 years agoload_rtl_netlist can't read compiler database
Hello
I'm new to Quartus and I'm trying to read back an elaborated design from quartus_syn, however when I run the 'load_rtl_netlist' I get the following error:
ERROR: Can't read compiler databas...
- 5 years ago
You may check the available command for each Quartus executables here: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/tclscriptrefmnl.pdf
KhaiY
sstrell
5 years agoCan you explain why you need to run this command? You can simply synthesize the design (as the error says) and then use tools based on the post-synthesis netlist like the RTL Viewer.
