10 years agoload .mif-file on DE0-CV board
-- i solved the problems i had. to see the solution have a look at post# 9 -- Hello community, I got a problem with my mif file. I've never worked with that before but I want to change ...
10 years agoHello Johi,
unfortunately I have no idea how your code works. I've never seen code like '$readmemh' before :/ I just want to initialize the memory on my board. But It starts with the problem: How to connect the mif-file with the other files to get an output file generated by compiling which I can upload on my board. I'm also not sure if I wrapped the memory file correctly to my main code. I've never done that before and have no idea how it works. I'll attach the code I got until now. Maybe you see a problem in the wrapping part (after the 'begin' of my architecture)? Best, orPoG
