ELave
8 years agoLinux/ModelSim: can't access Tools > Edit preferences
I've just run up the altera-18.0 ModelSim starter edition for the first time, on Centos/RH 6.10, Gnome. I'm on a HiDPI (4K) display and the output is too small to be comfortable. As a first step, I'...
KhaiChein_Y_Intel
8 years agoHi Elave,
You may check the OS here: https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/os-support.html
ModelSim Intel FPGA Edition / ModelSim Intel FPGA Starter Edition is officially supported in Redhat only.
You have to install the following additional RPM packages:
• 32-bit libraries: unixODBC-libs, unixODBC, ncurses, ncurses-libs, libzmq3, libXext, alsalib,
libXtst, libXft, libxml2, libedit, libX11, libXi.
