Linux/ModelSim: can't access Tools > Edit preferences
This isn't a symlink problem - I removed the 'linux' symlink, and copied in the linuxaloem code, with the same result.
This is almost certainly a 32/64-bit problem, or a tcl version problem. The shared object which implements 'Tools>Edit preferences' is:
$ file /home/eda/modelsim/altera-18.0/modelsim_ase/linux/ScintillaTk/libScintillaTk1.12.so
/home/eda/modelsim/altera-18.0/modelsim_ase/linux/ScintillaTk/libScintillaTk1.12.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, not stripped
I'm on Centos/RH 6.2, x86_64, tclsh 8.5. Can someone at Intel please give me a definitive answer on what is supported? Do you actually have to run this on a 32-bit system?
Stack trace below, when 'Tools>Edit preferences' is clicked:
Couldn't load file "/home/eda/modelsim/altera-18.0/modelsim_ase/linux/ScintillaTk/libScintillaTk1.12.so": libstdc++.so.6: cannot open shared object file: No such file or directory
while executing
".vcop Eval Console::PrefDialog"
invoked from within
".#mBar.#mBar#tools invoke active"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke active]"
(procedure "tk::MenuInvoke" line 50)
invoked from within
"tk::MenuInvoke .#mBar.#mBar#tools 1"
(command bound to event)
