Licensing of Intel desgin store
- 4 years ago
Depends on the design example, the IP that implemented in the design example might need a specific license to run and you will need to have this specific license. The design example can be downloaded without to have a license. You only need license to compile the IP.
If the design example does not contain any specific IP, then you can compile the design as it is.
regards,
Farabi
regards,
Farabi
