RNeto2
7 years agoLicensing Error in Simulation Waveform Editor
Hello everyone, I'm trying to run a simple simulation on a block diagram I built in Quartus Prime Lite Edition, the compilation is successful but I get a pesky error every time I run so I end up not ...
AnandRaj_S_Intel
7 years agoHi,
- Quartus Prime Lite Edition & Modelsim Stater edition does not required license/Daemon tool/environment variable settings .
- If you use Modelsim-Intel fpga edition you will get license error.
Try by using Modelsim Stater edition with respect to the Quartus version, Download from below link under tab Select by Software.
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
Anand
- RNeto27 years ago
Thank you! I had both Modelsim versions installed with Quartus and during simulation, Simulation Waveform Editor was constantly using the non-starter version and displaying the same error over and over because as you pointed out, it requires a license. After reinstalling the software and making sure only the Modelsim Stater edition was installed along with the correct device support, it's now working.
Really appreciate your help,
Ricardo
