License server service not starting
Could you kindly, re-confirm again the license setup process. You need to specify new location of the license file using the LM_LICENSE_FILE system variable. You need to set your LM_LICENSE_FILE environment variable to point to the license that Intel provide. c:\intel\license.dat or something similar.
2nd could you also ensure the port number. The port number is required for Windows systems and it should be outside of the 27000-28000 range and be unique on the machine. For example, 1800.
Please stop and restart the server after assigning port number. You need to allow the firewall access to the port number from both server and client machine. refer this to your license server admin
You can refer to link on how to set environment variable.
https://software.intel.com/en-us/articles/how-to-set-intel-license-file-environment-variable
You can also refer to the link below on Starting and Stopping the License Server
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
Refer this following youtube for license setup.
https://www.youtube.com/watch?v=Ob9ei5lMgGE
Hope this helps.
