lingxi10
5 years agoLicense server does not support this feature (alteramtivlog)
odelsim license not working, GUI can be open up and vlog is fine. When starting the stimulation, it gives to following issue: # vsim work.tb # Start time: 12:38:49 on Jun 23,2021 # # ** Licen...
Zawani_M_Intel
5 years agoHi lingxi10,
Good day!
You may check the MGLS_LICENSE_FILE and LM_LICENSE_FILE variable that has been set if it is pointing to the correct or latest license file/server.
You also may need to check if any firewall has been enabled and if necessary add exceptions for these ports in the firewall or disable the firewall and have try if you can get the license to work.
Thanks!
Wani
