17 years ago --- Quote Start --- Hi, [*]when using LmTools, you have to stick to the 8.1 version and under the tabular "Config Services" you have to update the "Path to lmgrd.exe file" so a new version of the lmgrd.exe is used at windows startup.[/LIST]Good luck, Roman --- Quote End --- Thanks for info, but i can not change anything with LMTools:( Mikuman
