17 years agoHi,
I had the same problem and eventually solved it.- Inside the license file there might be paths to old binaries (I don't know, if these had anything to do with the problem but they pointed to my 7.2 version...)
- when using LmTools, you have to stick to the 8.1 version and under the tabular "Config Services" you have to update the "Path to lmgrd.exe file" so a new version of the lmgrd.exe is used at windows startup.
