17 years ago --- Quote Start --- Hello, if i start ModelSim 6.3g_p1 (Comes with QII 8.1) i get an "License Error". See Attachment. No problem with MoedelSim 6.1g (Comes with QII 8.0). Variables are checked. Had someone an idea? Thanks --- Quote End --- Check the following on your system: 1. Is your license still valid or within expiry date? If you have a valid license, then the upgrades are usually supported on that license. 2. You wrote that the variables are checked. Do you mean that they are set correctly in the Environment Variables? Check if any paths to directories get changed. 3. Are you using the correct license port? 4. What are the results of lmdiag lmutil?
