License generated from self_service center not working
I generated the license file from self-service center from Intel website. The license file was generated successfully. I downloaded the file and specified the path to license.dat file in Quartus Prime Pro. However when I try to create a new project, it complains that it needs the license.
I used the NIC id to generate the license and double checked the NIC id is correct and also recognized by Quartus software, but license is still not working. Please help.
OK. I could not see LMTOOLS running. After some online searching, I found the following video, which shows how to setup a fixed node or floating license correctly. Following this video, I am able to setup my license correctly and don't see the error any more.
Thank you very much for help.
- AR_A_Intel
FYI, you can find debug.log file at LMTOOLS > path to the debug log file.
You can refer to this following YouTube on how to find debug log file (min.2:55)
https://www.youtube.com/watch?v=llLaWatUbe8
- veriguy
Duplicate. New to forum, posted again as was not able to find the original post today. The original post is as following. Please help. I am stuck.
- AR_A_Intel
Hello
Welcome to INTEL forum. To narrow down this issue. Can you provide your
1)full debug/error.log file
2) Error message screen shot
3) Quartus version use
4) Machine OS information
5) License.dat file
And for privacy, you can reply/attach your file in private message.
- veriguy
Thank you for replying. Where can I find the debug.log?
Anshu
- veriguy
- AR_A_Intel
Thanks for your update, hope all is well. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
