14 years agoIn the case of a fixed-node license, the LM_LICENSE_FILE variable should just be set to the license.dat file.
I don't remember there ever being a restriction under Linux. However, my Modelsim-SE license is served by a license server, so you might be correct. If you get your license file regenerated for use as a single floating node, you could then run flexlm on the same machine as you run Modelsim-SE. Cheers, Dave
