14 years ago --- Quote Start --- when i run the vsim application, the following error appears : unable to find the license file. it appears that your license file environment variable (e.g., lm_license_file) is not set correctly.
unable to checkout a license. vsim is closing.
** fatal: invalid license environment. application closing. --- Quote End --- The error message is telling you something, did you look at your environment variable? At a bash shell type: echo $LM_LICENSE_FILE It should be something like 1234@myserver. Cheers, Dave
