AWann1's avatar
AWann1
4 years ago
License does not contain information required to run
Hello, I am running Quartus Prime18.1 Standard Edition on Windows 10 Pro.
My company had purchased a floating license for the Quartus software. Another employee had been using it successfully. I used the same license a few months ago to compile their project, in order to confirm I had the license set up properly.
It worked as expected.
Now, when I attempt to compile a new project, I get the error message:
Error (292027): Specified license does not contain information required to run the Quartus Prime software.
I get the same result when trying to compile the old project that worked before. I haven't changed anything with regards to the license setup.
Does anyone have any experience with this?
Thanks!
  • sstrell's avatar
    sstrell
    Any chance the license expired? It is annual after all. Check in Tools -> License setup.
  • AWann1's avatar
    AWann1
    It says "Subscription Expiration: Not Found"
    I looked inside the License.dat itself, and it was generated February 24th 2022, so not expired yet.
  • AWann1's avatar
    AWann1
    Unfortunately, I can't even submit a support request for this because the link isn't working on Intel's site!
  • AR_A_Intel's avatar
    AR_A_Intel
    Hello
    To further understand the issue, could you get me the:
    1) license.dat file
    2) Full Output of “lmutil lmstat –a –c <port>@<address>” server and client
    3) debug/error.log (if any)
    For privacy, you can also reply/attach file in private message
    AR_A_Intel
    We do not receive any response from you to the previous reply that I have provided in private message mail. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
