--- Quote Start ---
Hello Together!
When I compile my project I get following error message: Current license file does not support incremental compilation (and I will not use it :-)).
That happens since I'm clicked "Add Node to SignalTap II Logic Analyzer". My next compilation shows mentioned message. Removing generated files from project didn't solve the problem. I also checked .qsf-file for entry INCREMENTAL_COMPILATION FULL_INCREMENTAL_COMPILATION as mentioned in Quartus II Help document but there is no word INCREMENTAL at all. In window "Settings" "Incremental Compilation" I couldn't select anything.
Used Version:
Quartus II 9.0 Buid 235 Web Edition
Service Pack Installed: 2
Help Version: Quartus II Help Version 9.0
Thanks for your support!
Best regards
R. Schrauth
--- Quote End ---
are you using Signaltap ?
Kind regards
GPK
