11 years agolibrary use clause errors
I am using Altera version 13.0.0. The compiler is complaining about this code: library ieee; use ieee.std_logic_1164.all; library basicblocks; use basicblocks.d_flipflop.all...
11 years agothe .all reference needs to be attached to a package. If the thing you are refering to is an entity, you dont need to call use on it at all if you dont want to, you can just use direct instantiation.
--no use cases required
--instatitate a d_flipflop
d_inst : entity basicblocks.d_flipflop
generic map (
--etc
port map (
-- etc
