14 years agoLibrary in QSYS
Hello everybody,
I've got a bit silly question about using QSYS. I usually work with several libraries. Each library contains a top representing an IP (such as, for example, MedianFilter IP in medianfilter_lib, UART IP in uart_lib, ...) When I use QSYS to integrate this IP, the .QIP file generated by QSYS mentionned for all IP 'lib_system' as the requested library... but in my cases, it is either medianfilter_lib, ... The result is that the analysis&elaboration process in Quartus fails (design library medianfilter_lib does not contain primary unit medianfilter_top). Do you have any workaround? Many thanks!
