15 years agoLibrary auk_dspip_lib not found. thanks
Hi all, I designed a system with FIR compilier . now. When I simulate the whole system using EDA RTL Simulation, I see this error below in modelsim. # ** Error: E:/Altera/Test_V80/IP/FIR/f...
15 years agomy guess is that you are simulating the source HDL which is encrypted. make sure you are generating the simulation netlist, and use the <fir_variation_name>.vho/.vo in your simulation instead of the the FIR library source files
