9 years agolibaltera_s5_ref_mmd.so: file not recognized: File format not recognized
Hi there, I am getting an error when trying to build the host application for emulation. All the flow (under a Linux Mint 18, essentially Ubuntu 16.04) works fine and I am able to run the kerne...
8 years agoHello Ruben,
i'm facing the same problem i changed the make file as you specified in your solution but this didn't work also, i have the same problem again did you manage to solve this just by this modification or is there something else to do. thanks in Advance
