Learning about Altera Verification IP
I live in the UK. The "new" link says:
Class Schedule
No class is being offered at this time. Request a class in your region.
It's working now.
- gyuunyuu5 years ago
Contributor
OK. This has been helpful to an extent.
The API contains many functions that start with prefix "signal_" and "event _". How are these supposed to be used? It is not clear to me so far. The get and set calls make sense.- gyuunyuu5 years ago
Contributor
It appears to me that the event_ functions are blocking calls. The signal_ are their counter parts that be used in a process to wait on i.e process will only execute when their is activity on the signal. The example code shows that the event_ functions are being used in the VHDL code while the signal_ functions are being used in the verilog code to do the exact same thing.
Contributor
Are the examples inside the ug_avalon_verification.zip supposed to work? I am getting considerable difficulty trying to get it to compile and run.
Contributor
The examples in the ug_avalon_verification do not work out of the box. I took quite a lot of effort to get them to work with my ActiveHDL by making changes to the scripts inside.
By the way, whenever there is an example project from Altera/Intel, the project itself is configured for Stratix or Arria device. Why is this done? Why not put a low end device in the project settings so the project can open on most people's computer without trouble? The same applies to Qsys files in example designs.
- RichardT_altera5 years ago
I understand your concern but I don't have the answer as to why the project itself is configured for Stratix or Arria device initially.
If you somehow able to made the project work using the low end device. Feel free to share here with the community the project/qsys file.
This may helps those who may having similar issue and vice versa.
Richard Tan
