8 years agoLatency of the loop
Would the latency of the below loop be different for switch_loop = 0 and switch_loop =1? The html report generated for the below kernel includes the latency of the global and local memory access. ...
8 years agoDo you mean that the multiplexer would wait for the FALSE condition although the TRUE condition execution is completed? Or does multiplexer has a fixed schedule to decide which condition is TRUE? I have attached the system viewer screenshot of kernel 1 (first post) and kernel 2. It looks like two parallel paths are not created as you told. The two conditions are in serial.
