13 years ago --- Quote Start --- Hello, does anybody know, why Quartus infers latches for the below combinational function if we use an initial value expression for the variable definition of mirrored_data? I looks like a Quartus bug at first sight, because all output bits are actually defined, there's nothing to be latched. The latches are generated for the function result. If you register y in the upper level, the problem disappears. The problem is originated from this Edaboard discussion: http://www.edaboard.com/thread273938.html Best regards, Frank
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
ENTITY test IS
GENERIC (
PORT (
x: IN UNSIGNED( size DOWNTO 0);
a: IN INTEGER RANGE 0 TO size;
b: IN INTEGER RANGE 0 TO size;
y : OUT UNSIGNED (size DOWNTO 0));
END;
ARCHITECTURE FLOW OF test IS
function mirror ( data : unsigned ; top : integer ; bottom : integer ) return unsigned is
-- Using an initial value expression in this place causes latch inference, why?
-- variable mirrored_data : unsigned ( data ' range ) := data;
variable mirrored_data : unsigned ( data ' range );
begin
mirrored_data := data;
for index in 0 to data ' length - 1 loop
if (index <= top) and (index >= bottom) then
mirrored_data ( index ) := data ( top - index + bottom ) ;
end if ;
end loop ;
return mirrored_data ;
end function mirror ;
BEGIN
y <= mirror ( x , a , b ) ;
END FLOW; --- Quote End --- Have you tried bitwise intialisation of mirrored_data: mirrored_data(0) := data(0); mirrored_data(1) := data(1); ... then apply loop.
