8 years agoKernel performance with profiling
Hello again guys. Im struggle to understand the results from the profiler of two kernel versions (one with unroll factor of 128 and another with 32) The 32 unroll factor outperforms the 12...
8 years ago --- Quote Start --- If you are talking about the number reported by the profiler, I think it is in 32-bit words, not bytes. --- Quote End --- On profiler reports says that the max burst size is 16.. but 16 bits, bytes, number of requests? bandwidth Burst Size The average burst size of the memory operation.If the memory system does not support burst mode (for example, on-chip RAM), no burst information will be available. Average Burst Size=7.6(Max Burst=16) Global memory
