8 years agoKernel performance with profiling
Hello again guys. Im struggle to understand the results from the profiler of two kernel versions (one with unroll factor of 128 and another with 32) The 32 unroll factor outperforms the 12...
8 years ago --- Quote Start --- The compiler combines unrolled consecutive accesses into larger coalesced accesses to improve memory throughput. I am not exactly sure where the LSU sits in the design, most likely between the kernel and memory controller. Regarding latency, my understanding is that the latency reported in the report for LSUs is the number of registers the compiler inserts into the pipeline to absorb stalls from memory accesses. If the access gets stalled for less clocks, only bubbles will be inserted into the pipeline. If the stall lasts longer, then the whole pipeline will be stalled. Please note that these stuff are not really documented anywhere, and I could as well be wrong. --- Quote End --- Thats why i cannot infer too much about LSU, i check the memory design and nothing about this resource. The burst size of the LSU is the number of request it can coalesce in bytes?
