8 years agokernel driver mismatch after switching from SDK 16.1 to 17.1
We have recently switched from SDK16.1 to 17.1 The aocl diagnose works fine. The aoc -list-boards shows the boards as expected. The aoc full compile works. The make works for the host pro...
8 years agoYour "aocl install" suggestion confuses me.
If I understand the error message correctly, it says the FPGA board has a 17.1 kernel (which is what I want since I'm using SDK 17.1). But, the host wants a 16.1 kernel. Why? This sort of implies that the host is using 16.1 but I compile the host code with SDK 17.1. ???? Why does the host want a 16.1 kernel? I'm using SDK 17.1 tools to - aoc to create the FPGA ".bit file" - run "make" to make the host file How do I re-compile the host code with the new BSP? Doesn't the OpenCL code need the BSP? I did use the the 17.1 tools when running "make" to compile the host code.
